Changing IFC class for system families
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
andjelija.sandicJBBP3
1484 Aufrufe, 4 Antworten
Hello guys,
Is it possible to change IFC class for system families? I. E. for walls from IfcWallStandardCase to IfcWall? As far as I can see, IfcExportAs parameter couldn't be used for system families.
Thanks in advance
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: andjelija.sandicJBBP3
It is in many cases already set in the export options.
However internally, depending on the standard (e.g 2x3) you choose it is translated by Revit into IfcWallStandardCase.
When you choose a different standard it might be translated to a different one (here IFC4 reference view) like IfcWall
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
als Antwort auf: L.Maas
Thank you very much!
Nachricht 4 von 5
yes but there aren't any possibility to change IfcClass from System families. Sometime happen that is quite easy to model a geometry with a system family and decide to change its IfcClass. this works only with load families
Nachricht 5 von 5
als Antwort auf: Anonymous
Thank you, Mauro!
So to conclude - we cannot change IfcClass from System families, we are left to work with the IfcClasses that are defined by different standards.
