IFC Export Level / Elevation
davi-id
davi-id
Hello.
I need to export an ifc model in the mvd 2x3 with installations connected to the right level.
Me and my collegues copied installations from level to level and now every level is mixed with installations from different levels. To fix this I thought to select everything and just change the level. Thats just possible for one installation type (for example I could change this for pipes, but need to repeat it for pipe fittings and insulation). It would take a really long time this way, so I thought about using Dynamo. However I couldn't change it this way either (I'm not sure if it isn't possible or that I'm just too inexperienced).
Lastly I thought about using an IFC-Parameter which I could change through Dynamo or by using a schedule.
Sadly I didn't find something fitting or it doesn't work. For architecture I found this post:
https://forums.autodesk.com/t5/revit-architecture-forum/workplane-based-element-ifc-mapping-for-leve...
sadly "IfcSpatialContainer" isn't working for my MEP-elements. I guess this is because Revit maps an existing level - rather than overwriting it with my custom parameter.
Are there more options? Did I miss something?
I really apperciate your help. Thanks in advance! 🙂
rushabhthakkar_910
These might help you..!!
parameter IfcSpatialContainer (value = level name).
👆(https://forums.autodesk.com/t5/revit-architecture-forum/ifc-export-level-override/td-p/9725057)
(https://help.autodesk.com/view/ADSTPR/2023/ENU/?guid=GUID-384D2EDA-5BF7-42B9-99D3-A333D59389FB)
(https://help.autodesk.com/view/DOCS/ENU/?guid=Model_Browser)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
davi-id
Sadly this doesn't help. But thanks for your links. I also can't upload the ifc-file so I'm uploading a Revit example. If exported to Revit 2x3 the light fixtures in the level "Ebene 4" should be mapped to "Ebene 4" not to "Ebene 2" with an elevation.
