IFC Export Level / Elevation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I need to export an ifc model in the mvd 2x3 with installations connected to the right level.
Me and my collegues copied installations from level to level and now every level is mixed with installations from different levels. To fix this I thought to select everything and just change the level. Thats just possible for one installation type (for example I could change this for pipes, but need to repeat it for pipe fittings and insulation). It would take a really long time this way, so I thought about using Dynamo. However I couldn't change it this way either (I'm not sure if it isn't possible or that I'm just too inexperienced).
Lastly I thought about using an IFC-Parameter which I could change through Dynamo or by using a schedule.
Sadly I didn't find something fitting or it doesn't work. For architecture I found this post:
sadly "IfcSpatialContainer" isn't working for my MEP-elements. I guess this is because Revit maps an existing level - rather than overwriting it with my custom parameter.
Are there more options? Did I miss something?
I really apperciate your help. Thanks in advance! 🙂
