IF Statement from a Shared Parameter - Tile Blocks
mark.donkin
mark.donkin
Before I go too far down the rabbit hole i'm would like to check if the following is possible.
Not everyone in the business currently understand the ISO19650 Status codes so I want to put a small description of what the status code means at the bottom of each titleblock Sheet.
The drawing can only be a number of Status's eg. S0, S3, A4, A5 etc. I want to create a lookup formula that looks for the two digit status in one shared Instance parameter and then displays the description of that status in a different parameter e.g.:
ISO19650_Status = S0
ISO19650_Status_Definition = IF (ISO19650_Status = S0 THEN "Work In Progress), IF (ISO19650_Status = S3 THEN "Suitable for Review & Comment") etc... I know the syntax is incorrect at this point.
Any help would be most appreciated.
Cheers
You cannot use any text parameter to drive a formula. It could work if you use a number or integer parameter: 0, 1, 2... instead of S0, S1, S2... then add S as a prefix to the label.
mark.donkin
Ok thanks for getting back to me that has saved me some considerable time. I may be able to work a solution using your tip.
Cheers
Mark
