I´ve lost all my Revit templates - how do I get them back
AidanHawkins
AidanHawkins
I use Revit 2023
I somehow lost all my templates... they show up as none
How can I get these back?
Aidan
alexgantsidis
View->View Templates (drop down) -> Manage View Templates. On the "View type filter" set it to <all>. Can you see them now?
If not, Open another project at the same time (which it has the view templates) and then on the first project: Manage-> Transfer Project Parameters -> check the View templates -> OK
AidanHawkins
This is for project templates yes??
alexgantsidis
You said templates and I thought you were talking about view templates, not project template
AidanHawkins
Sorry to clarify - its project templates im missing
Have you checked these locations?
You lost CUSTOM Templates (RTE) or you lost the OOTB Templates (RTE)?  Are they not at the location specified under Options=>File Locations?  The default path to the OOTB Templates are usually here:  C:\ProgramData\Autodesk\RVT [year]\Templates\[language]
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C....
