I'm getting an error while Daylight Simulation
mehmetbilalsener
mehmetbilalsener
After creating my model in Revit, I am trying to Simulate Daylight for LEEDv4 in the Lighting option with the Insight plugin. But after 5 minutes I get the error "Failed to export document to SPD. SPD export failed. Check you have permissions". I searched for solutions.
It is suggested to use the Render in cloud path, but when I try that path, "Render in cloud, error code -1" error occurs.
Thanks in advance if anyone can help.
What version of Revit?
mehmetbilalsener
Revit 2020
RDAOU
@mehmetbilalsener
ANy firewall which you can disable?
Is it a Cloud based model? if yes,  try to Save As command a local model and run the analysis on the local copy...
Otherwise try the solution given below:
  1. Solved: SPD export failed - Autodesk Community - Insight
  2. And the discussion HERE --->>> Revit Lighting Analysis Error & Questions - Autodesk Community - Insight
