Revit Lighting Analysis Error & Questions
- Mute
- Permalink
- Report
I am working on a office building daylighting analysis. I have turned off all the mass and extra model elements in the project _lighting analysis model 3d view. I am still getting an error 'failed to export document to SPD. SPD export failed. Check you permissions.' Can you please help us understand the issue ?
I do have other questions on revit lighting design plugin.
a) We have a double pane glass as per project specifications. In the revit file the glass is only modeled as a single pane for simplicity. I would like to know can we still peform daylight simulation just by changing the RGB values as per steps below (see link below) or do we have to model a double pane glass in the revit file first and follow these steps afterwards ?
b) We ran a daylight simulation on a previous project and had some issues. We only wanted to analyse few spaces on different floors in a multistory office building. How can we hide the analysis grid after the simulation is complete ? We noticed the section box does not hide or isolate the analysis grid on different floors.
c) Is there a way to change the analysis grid size from 10 feet by 10 feet to a different number ? This will help us analyze some non LEED projects.
d) How can we place an analysis grid on a vertical surface like wall, etc ?
e) Is it possible to view foot candel levels on the analysis grid. See attached image from radiance ?
We appreciate your help.
Regards
Sushant Verma
sushant_verma@gensler.com
