Announcements
SPD export failed
SPD export failed
Greetings Sir/mam,
I've been trying to run some energy performance analysis for a building model I'm currently working on. I have run Heating/Cooling load analysis with no problem and when I try to run a Lighting analysis I get a message
"Failed to export document to SPD. SPD export failed. Check you have permissions."
I currently have a student subscribtion. I have seen on the mangament profile under "Product and services" a option of "
Insight - Lighting Analysis for Revit - student".
Should I have access to the Lighting analysis for Daylight analysis?
I'm running the Revit2018, since yesterday because I had some problems with Insight on the Revit2016 version. I uploaded a picture that shows the message and can be seen that I'm running a student verison of  Revit.
Best regards,
Axel
Hi @Anonymous
There were a few previous forum posts with answers to the same problem.
https://forums.autodesk.com/t5/lighting-solar-analysis-forum/daylight-analysis-error/m-p/7794902/highlight/true#M1125
https://forums.autodesk.com/t5/lighting-solar-analysis-forum/revit-lighting-analysis-error-amp-questions/m-p/5764742/highlight/true#M190
https://forums.autodesk.com/t5/lighting-solar-analysis-forum/updated-lighting-analysis-in-the-cloud/m-p/6714829/highlight/true#M574
In the future you can search through the forum to see if others have encountered similar issues. Often you can find answers that way without needing to wait for a response.
Hope this helps!
Please click the "Accept as Solution" button if this solves your issue or answers your question so that others may also benefit from the information
