I have problem with the scale
m.alewi
Message 1 of 17
m.alewi
I'm having trouble with the scale and text looking weird. Anyone know why this happens?
Replies (16)
Message 2 of 17
Simon_Weel
Either the text size is too high or the labels / text fields are too narrow.
Message 3 of 17
m.alewi
When I send the rvt file to the teacher or someone else who has revited, it looks right on them but not on me. The teacher said that the problem might be in the font in the operating system, but I don't know how to solve it.
Message 4 of 17
m.alewi
Message 5 of 17
Simon_Weel
Open the Family and stretch the text fields?
Message 6 of 17
m.alewi
I wanna try and see.
Message 7 of 17
mhiserZFHXS
Did this start as a template file from someone else? Your teacher may be correct. Find out what the font is and see if its on your computer.
Message 8 of 17
m.alewi
Thank you but where can i fount the font in my computer?
Message 9 of 17
mhiserZFHXS
C:\Windows\Fonts
If the required font isn't there, have someone else email it to you. They can pull it from the same folder on their computer. Your teacher would probably be a good bet.
Message 10 of 17
m.alewi
Thank you very much i will check that in evening.
Message 11 of 17
m.alewi
Hi again, do you know how to found wich fonts Revit use to scale? I try to found but don't no where.
Message 12 of 17
TripleM-Dev.net
Hi @m.alewi,
Is this a snapshot from Revit view itself or a Exported PDF from Revit?
- Michel
Message 13 of 17
m.alewi
Is from Revit. When I send the rvt file to my teacher, it looks right. I sent the rvt file to a friend who works as an architect and with him it is correct. They suspect that the style found in revit is not present in the OS. Something that makes it so.
Message 14 of 17
TripleM-Dev.net
Hi @m.alewi ,
The scale element is part of the titleblock?
Then select titleblock and rightclick on it and select "Edit Family"
Next select the text (can be a textnote or label) and check in it's type (Edit Type) which text font is used
If the font property is empty, then the font most likely doesn't exist on you're system, if so have someone check it's font and have it installed.
- Michel
Message 15 of 17
m.alewi
I put the RVT file here. I try with that you show but check its opened a new side and looks like the picture.
Message 16 of 17
TripleM-Dev.net
Uhm, I don't have R2023 installed on current system.
You are almost there, select one of the text elements and then check it's font property by clicking on "Edit Type".
Message 17 of 17
m.alewi
Thank you very much now its working. Thank you i am very happy because i ask 3 person and nobody know how to help me. I can no sleep and be happy. Thank you again my friend.
Best regards Adam
