Wall level problems
Wall level problems
anh_nguyenphuong059
Wall level problems
anh_nguyenphuong059
Right now, im having problem copying wall when drawing in BIM project. There are a few model in my Central file right now, example: A, B, C. I dont know why when i copy wall in level 2 (model A), the walls are not attached to level 2 (model A). The copy one keep attach to level 2 (model C). Same to model B. Here is the example picture for my problem. The second pic is my copy wall. Can anyone help me solve this problem?
Hard to troubleshoot without seeing the RVTs.  Post them here.
anh_nguyenphuong059
I cant post the file due to size problem but here is the video i take when doing that progress. Can you check it?
(view in My Videos)
syman2000
Question - is the level 2 A, B, C at different level or it is close to each other? Revit typically copy object to the current plan associate level. So if you have wall at Level 2 A and the associate is Level 2 B, the Level 2 B will be the new host.
anh_nguyenphuong059
anh_nguyenphuong059_0-1689733816562.pnganh_nguyenphuong059_1-1689733832041.pnganh_nguyenphuong059_2-1689733847039.png
yeah it on the same level from ground. the floor plan asscosiated level to 11.level 2 but when copy it still associate to 14.level 2 😞 even other element that far from building no 14, the copying elements still attach to this building level
