I'm having a problem with newly added Toposolid revit.
26 ANTWORTEN 26
Nachricht 1 von 27
Luis_eduardo201
3900 Aufrufe, 26 Antworten
I'm having a problem with newly added Toposolid revit. The topography has triangles that do not match the topography of the dwg. I have attached the topography in case anyone wants to test it.
Tags (3)
Beschriftungen (2)
26 ANTWORTEN 26
Nachricht 2 von 27
als Antwort auf: Luis_eduardo201
What about Floors from the Polylines?  Kind of like chipboard modeling. :zwinkerndes_Gesicht:
Nachricht 3 von 27
Nachricht 4 von 27
u_pekli
als Antwort auf: barthbradley
You're joking right ...
That's a major issue from Revit 2024 ! toposolid doesn't match de 3D DWG !!!
I've lost half day, and still no solution.
Nachricht 5 von 27
I have similar problem, when trying to import the surface created in Civil 3d to Revit.
Solution that is provided is to export the surface directly from Civil3d to Bim360 and insert it into Revit. However, when I insert the toposolid, there is an error saying "Slab Shape Edit failed." and this removes all levels of the surface and gives me just the extents all in one level.
Does anyone know a solution for this?
Nachricht 6 von 27
Allan-Wise
There is something seriously wrong with the new toposolid tool. In revit 2022 it worked perfectly many times with the old toposurface. Toposolid is not creating an accurate surfaces. Not even close.
I have a shared surface from Civil 3d in Autodesk docs.
Nachricht 7 von 27
Allan-Wise
Autodesk have published this article too. This is a serious issue in Revit 2024. I just banned starting new projects in Revit 2024 in our company till this is resolved:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Inaccurate-toposol...
Nachricht 8 von 27
snoyola
In my youtube channel, I have posted some videos analyzing the flow between revit and civil, in revit 2024 the proper flow is to use the civil 3D project as a reference, because the revit TIN algorithm is different from the Civil TIN algorithm. Revit re-generates the surface, and that is rework!
Simon Noyola
Nachricht 9 von 27
ar00302
Send me the dwg triangles and I will make an exact toposolid for you. I will use rhino inside for this.
Nachricht 10 von 27
snoyola
als Antwort auf: ar00302
@ar00302
What you mean is that with Rinho, it takes the Civil 3D surface and leaves it identical to Civil 3D, but in Revit?
simon Noyola
Nachricht 11 von 27
ar00302
als Antwort auf: snoyola
Yes I  will add it exact the same as produced by civil 3d using grasshopper rhino inside. Probably you can do this with Dynamo but I work with grasshopper
Nachricht 12 von 27
Allan-Wise
Can we please get Revit updated to do surfaces properly. It doesn't even
have grading tools to make batters for example. You always have to go to
another program to create the surface correctly. The new Toposolid doesn't
even work correctly for Civil 3D Autodesk Docs links anymore. We have to go
back to an old version of Revit, create the Toposurface, then upgrade this
model and copy and paste this surface into our Revit 2024 project.
Nachricht 13 von 27
u_pekli
Exactly... can't beleive they changed something working.
How do you create a modified surface if you import from old Revit ? ... you need to recreate manually a surface in 2024 ?
Nachricht 14 von 27
doug_cummings
TopoSolids in 2024 have a 10,000 point threshold before they are automatically simplified (points removed) to stay under that number. 2023 and below Toposurfaces did not have this limit.  I would verify the number sin points in C3D surface to see if this is the issue for your surface.
Nachricht 15 von 27
Allan-Wise
als Antwort auf: doug_cummings
I was using a TIN surface in Civil 3D.
Nachricht 16 von 27
janeEYBNR
How do you do this efficiently?
Nachricht 17 von 27
donker.bim
In Revit 2025, the Problem is still exactly the same.
Toposolids are not usable for us, when the surface is not accurate.
Nachricht 18 von 27
janeEYBNR
How do you do the chipboard model in Revit 2024 efficiently?
Nachricht 19 von 27
froilanallan
this is how I do landscape in Revit 2022 using toposurface.
Now I am back to stone age using revit 2024 toposolid. My boss wants to fire me out. Plaese bring back toposurface AUTODESK!
Nachricht 20 von 27
lizUU72Y
Autodesk, there are so many other issues that you could be "improving", such as navigation within the camera tool interface. This is absurd. Why change what people liked.
