I have no way to access shared Revit 360 files from within Revit 2020
9 REPLIES 9
Message 1 of 10
daniel.p.wolcott
653 Views, 9 Replies
My group is using worksharing on BIM360. I was sent an invitation to the project and got set up on the BIM 360 web site with the proper permissions. When I open Revit, there is no BIM 360 icon on the home screen. When I try to publish a project under collaborate, the BIM 360 option is grayed out. We are all using the Student Version of Revit 2020. My teammates had no problem accessing the project from BIM 360
9 REPLIES 9
Message 2 of 10
DarrenP
in reply to: daniel.p.wolcott
you still need a license for bim 360 as a student this is not available unless your school was selected by autodesk for testing
can you confirm you do have a license of BIM 360?
DarrenP
Message 3 of 10
daniel.p.wolcott
in reply to: DarrenP
I'm able to log into BIM 360 online and see the project and my teammates (also students) are working with the BIM 360 model in Revit with no problem.
Message 4 of 10
you can refer to this LINK and see if helps. thanks
Message 5 of 10
Thanks for the link. Unfortunately, I've been to this page a few times and it doesn't quite address my issue. There is literally nothing showing under Recent Files on the home screen. Not just no files listed, but no BIM 360 icon. I do have full admin permissions to the project on the BIM 360 web site.
Message 6 of 10
DarrenP
post of a screenshot of what your seeing
DarrenP
Message 7 of 10
I've attached a screenshot, but I've also done more troubleshooting. I have the same result on my laptop and my desktop, which tells me it's not a problem in my Revit installs, but rather a problem with either my BIM 360 accout or with the Central model.
Message 8 of 10
ennujozlagam
i think you won't be able to see the BIM 360 icon from there, you need to click open, something like this see attached screenshot. thanks
Message 9 of 10
The BIM 360 option was removed from the Open dialog in Revit 2020. It now lives under the recent files on the home screen (or it's supposed to).
Message 10 of 10
Problem solved. Apparently my administrator spelled my name wrong. Everything has been fixed and I now have access and am no longer feeling like I'm going crazy. Thanks everyone for your help.
Forma Design Contest
