I have a problem to open my template files and my old projects.
9 REPLIES 9
Message 1 of 10
bai-fearn27
411 Views, 9 Replies
bai-fearn27
Hi. I have a problem to open my template files and my old projects that uesd the template. When i open it, my project will update to the previous version untill it showed 'Ready' the files don't appear. And the program always showed Not responding every time.
9 REPLIES 9
Message 2 of 10
bai-fearn27
in reply to: bai-fearn27
bai-fearn27
This's happening to my Revit after I try to open my template. It takes time about 1 hr.
Message 3 of 10
syman2000
syman2000
Upload the template so we can take a look. What Revit version is the old template use?
Message 4 of 10
HVAC-Novice
HVAC-Novice
What version to what version? Looks like you use 2024.1. . What version is the old file? Technically you are supposed to upgrade one version at a time.
"my project will update to the previous version"
this doesn't make sense. Revit will update to the version of the Revit that is open. So your R2024 being open will upgrade any older files to R2024, not to some older version.
Revit version: R2025.3
Message 5 of 10
bai-fearn27
in reply to: syman2000
bai-fearn27
I use Revit 24 and my template is Revit 24.
This is my template. >> https://drive.google.com/file/d/1ydhoWg66SsDxm1Y2_2qUfn4gh7sI01J2/view?usp=sharing
I can't open it from version 23 so i sent this template to my friends then he upgraded it to Revit 24 but I still can't open it, but he can.
Message 6 of 10
bai-fearn27
in reply to: HVAC-Novice
bai-fearn27
I use Revit 24. The template is version 23 and i can't open it so I sent this template to my friends then he upgraded it to Revit 24 but I still can't open, but he can. My old projects that built from this template can't open too.
Message 7 of 10
natkophong_s63
I have the same problem. I use R24. My template is R23 and project files that use the template cannot open too.
i cannot open your file from link.
Message 8 of 10
syman2000
syman2000
Can you provide older version of the template and see if we are able to upgrade to 23?
Message 9 of 10
HVAC-Novice
HVAC-Novice
Opens fine on my R2024.1
Message 10 of 10
SteveKStafford
Test it with a different template file from Revit 2023. If that opens then there is something unique happening on your PC, and possibly with the template but since it is opening for other people...that's not very likely. Verify that you have read/write access to the folders these files are located on. I've seen EyeTee change things and inadvertently cut off certain users access.
Assess what add-in's are installed on your PC, check for OS updates that have failed or many that haven't been installed yet. Just to rule it out, try changing back to the light UI...the dark UI is new, who knows maybe there are graphics cards or configurations that Revit doesn't like.
Steve Stafford
Steve Stafford
