i couldn't coordinate Cad File with revit File
mahyarSOORANI
mahyarSOORANI
we have 2 geographical points and entering to CAD , after Saveing Cad File and link it on Revit . i see a Error Coordinate on one of the points
see pictures Please :
in AutoCAD points Are both Correct
But After Link On the Revit Upper Point Coordinate Will Have Error !!!! In both Software True North Are UP
Are these REVIT Spot Coordinates?
If so, there is definitely something weird going on.
Post the DWG so we can test.
...in fact, post both the DWG and the RVT.
Actually, never mind.  The relationships between the points in the DWG and the relationships between the points in RVT match precisely.  Select the DWG Link in Revit and press Acquire Coordinates. Then change your Spot Coordinate's Coordinate Base to Survey Point.
mahyarSOORANI
thanks for your help . i found it .... 😂  i was entring the numbers vice versa . i must enter X CAD number to East/West In revit and Y Number In North\South , that i was doing contrariwise 😅
