i have attached a image ...i want to a dd more control points in an adaptive environment ..so that I can move other leg of beam .....
Why? You only have one Profile from what I can surmise. What would 2 additional APs accomplish?
Adding adaptive placement points at these locations will not help you achieve what you are asking for.
This family is based on 2 points and a profile...ie:
Thanks for replying.....profile is same but all dis six point keep changing...i want to make this 6 point adaptive...... with different point location but profile is same
You cannot simply add points to what you have...you need to remodel the family and the profile as a 6 points Adaptive component.
Why don't make the profile parametric? That way you can adjust the side easily and you don't need to add additional adaptive points. The more points you add to Revit, the more unpredictable behavior it can be.
