My machine is a Intel Corel i7-7700K 4.20GHz, 64 Gb Ram, NVIDIA GeForce GTX 1080 , and I have some Autodesk products for example Revit 2018, 2019 y 2020.
I use Revit 2018 and 2020 very well
But sometimes ago I have the same problem in Revit 2019 and I can´t use it.
I open it, I place a wall any of the ones that comes with Revit and then I try to just install any of the libraries that comes with Revit and it tells me
"FAILED TO APPLY FAMILY PARAMETERS"
Try different templates that come with revit, with different doors, windows, columns, etc., and never let me do anything.
I attached 2 images
I have to use for a new project 2019 and I can´t
Could you help me please!
Thank you
Solved by ennujozlagam. Go to Solution.
Hi @Lucrereal
Please delete the journals, install the latest hotfix for Revit 2019 and reboot.
Check if the issue reoccurs, if not please share the journal file.
Related article: Family Parameter Requirements
Best Regards,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
have you try to clean uninstall and reinstall again it could some programs files are corrupted..just saying. thanks
Thanks for the tip @ennujozlagam
@Lucrereal and me were able to connect and resolved the issue, with clean uninstall and reinstall in D:Drive.
Viveka CD
Hi there, I have the exact same problem as this person and have tried doing a clean uninstall but I don't think it's working. How can i follow the steps to clean uninstall the program? I can't load any family (furniture, doors, anything) therefore I can't use revit.
Hi, I got the same problem. I get errors like this every time push the "Door" or "Window" button in Architecture:
I have tried to delete all Autodesk files in Windows and reinstall Revit, but i still get the same error.
Please help!
I have tried to delete all Autodesk files in Windows and reinstall Revit, but i still get the same error. I`ve also installed the latest hotfix.
Please help!
Follow these steps to resolve the issue:
Alternatively:
Copy and paste a healthy DDGraph file from another machine, where the issue is not reproducible.
If the above steps do not help, clear the content of the following folders:
%USERNAME% should be your windows login name.
%VERSION% should be your Revit version.
Thank you SO MUCH for both fast raspond and fantastic help! It worked renaming that file. Thanks!
