I can`t select any items in this project
PS224358
Message 1 of 11
PS224358
I just received this project as you can see in the picture I can't select any element. I tried several methods but none of them work.
I also don't see the architect's plan.
Would it be a problem because it is not included in the project? Should it be separately loaded?
Than k you !
Replies (10)
Message 2 of 11
RDAOU
@PS224358
Check the Select Drop down Options and see if you need to enable any
Check the Manage tab >> Manage Links and reload the Architectural Model...if the lined model is missing, ask them to send it as well!!
If you could, attach/upload the model for a closer check
Message 3 of 11
syman2000
Perhaps the object is placed in design option. Check off exclude options
Message 4 of 11
PS224358
I try to select all the them but i still can`t select any item.
Message 5 of 11
PS224358
If i check off the exlude options than i can select all of them in full screen.
Message 6 of 11
RDAOU
@PS224358
Go to Manage > Design Option and Make it primary then
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-M...
Message 7 of 11
PS224358
I can select now all the items but i can`t select any apart to edit. Is this not possible?
Message 8 of 11
syman2000
It is revit link. You cannot it unless you open the link Revit model and edit from there.
Message 9 of 11
PS224358
I don`t what exactly do you mean. How can i edit this model?
Message 10 of 11
syman2000
Look at your screenshot that you've provided. It said RVT link. You go Open and find this file. Edit whatever you want to do and then save.
Message 11 of 11
PS224358
It`s solved. Thank you for your time !
