Dimension label
Dimension label
yes_and_no
Dimension label
yes_and_no
Happy Thanksgiving, guys.
Q: how can I remove or hide the equal sign in dimensions label ? For example, I can live with "VIF., 55'-2" but not "VIF.=55'-2", different meaning and responsibility here.
syman2000
You double click on the dimension and replace it with text
yes_and_no
Hm, I was thinking of creating dimension style associates with phasing (old/new), select all and in one click, adding "VIF" to all.
Do you have other suggestion ? I am in R17.
You can add prefix suffix to a dimension type in Revit 2022.
syman2000
If you are using Revit 2017, you may have to look at Dynamo as your solution. This prefix/suffix was added to 2022.
https://forum.dynamobim.com/t/changing-dimension-prefix-dynamo-python/5052
