Can light switches and electrical outlets show up in elevation views?
2 ANTWORTEN 2
Nachricht 1 von 3
1114 Aufrufe, 2 Antworten
I'm creating my first electrical and reflected ceiling plan in Revit.  I've input the existing switches and electrical outlets in plan view.  Is there a way to have the switches and outlets show up in elevation view at the height I specify? The standard families only seem to have information on plan view.  Any help is appreciated! Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Not sure how to delete this post but I'm realizing I used annotations instead of the families. Please disregard the above post.
Nachricht 3 von 3
mariano_biagioli
Hi Marie,
Absolutely.
You need to edit the family.
If you want to see the element you already see in 3D in the floor plan/ elevation, select the geometry in the family and edit the Visibility settings and turn on the plan view/ elevation visibility.
If you want to see a symbol in the floor plan/ elev, you need to create model lines, and then convert them to symbolic lines, and the same, set the visibility properties to see them in the elevation or plan view.
Let me know if you need more help on this.
