I can't see my images in drafting views
8 REPLIES 8
Message 1 of 9
Pantaleon02
2241 Views, 8 Replies
I have Revit 2017 and i'm trying to insert an image in a drafting view...
I insert the image... I save the file... close revit and when i open it again the image is gone... the only thing left is a box with and x on it. And no image.
So I tried it in another pc with Revit 2016, and it works fine there but not in my computer (revit 2017)
The image is a JPG format.
8 REPLIES 8
Message 2 of 9
in reply to: Pantaleon02
Do you use OneDrive cloud drive (sync'd with a local folder) to store your files?
Message 3 of 9
Pantaleon02
in reply to: ToanDN
No, I didn't use Onedrive...  The image was in a folder in my desktop... 😕
Message 4 of 9
Can you try again with the image in a new folder in the C: drive?
Message 5 of 9
Pantaleon02
in reply to: ToanDN
That worked thanks!... But now I always have to put my images in a folder inside C: drive? 😕
Is this supposed to be this way?
Thanks anyway 🙂
Message 6 of 9
No you don't always have to save files in a folder in C:.  It is just a test.  I think there is some permission issues when files saved in one of the User's folder under Windows 10 (Desktop is one of them).
So you can create a Project folder somewhere outside of the C:\Users\.  I suggested C:\Projects\ just for easy access but it's up to you.
Message 7 of 9
Pantaleon02
in reply to: ToanDN
Ok... 🙂
I actually don't like to poke around in the C: drive folder because that's where all program files are...
By inserting an image to revit, is it saving the image inside the project or not? i mean... will the image be embedded to the project file? If i but the project in a different computer will i be able to see the image?
Message 8 of 9
@bluepantaleon02 wrote:
Ok... 🙂
There are a few folders you should stay away, such as anything with Program..., Windows..., Users...  There are no harms to create new folders in C:\ but as I said, up to you.
It is supposed to work like that.
I had the same glitch on my home computer.  But when I open my file in the office computer, I have no problem seeing the images.  My office computer runs Windows 10 Enterprise and my home runs Windows 10 Home.  May be that is the reason.
Message 9 of 9
Pantaleon02
in reply to: ToanDN
Thank you 🙂
