How to you create a railing profile hosted by the toposolid/topography to represent the building envelope (or buildable zone)
5 REPLIES 5
cvoo0001
543 Views, 5 Replies
Hi Everyone,
I am trying to use a railing profile boundary of the buildable zone of the land. Please see the attached profile. However, I am struggling to get this file to work everytime I try to pick the toposolid as the host. Please also find an example image attached (I used Rhino to create the building envelope and import it into revit). Could anyone please help me with a step-by-step solution? I am new to Revit and not very familiar with the settings in Railing.
Thanks in Advance,
Labels (4)
5 REPLIES 5
syman2000
in reply to: cvoo0001
When you create the railing profile, you have to create reference plane to ensure you get the consistent outline. Once you do this, you
When you load into the project, you want to set the offset 3m away from property line.
Then host the railing on the topo site and it should follow the topo. See attached
cvoo0001
in reply to: syman2000
Hi Syman,
Thank you so much for such detailed tutorial and revit file. Everything works like a charm!
cvoo0001
Hi Syman2000,
I just realised after I imported the railing to my revit file it has 2 problems:
  1. There are breaks
  2. It is not always vertical
I have attached the screenshots and the revit file in this post, can you please have a look and let me know how to resolve them?
Kind Regards,
Ryan.
syman2000
Railing will break if there is a huge variation in slope. So instead of using continuous rail method, the other option is use baluster. Sample below shows baluster able to conform to the site with various See attached
cvoo0001
This works! Thanks a lot!
Forma Design Contest
