How to use a UK date format in Revit?
Message 1 of 13
I would like to use a UK date format ie dd/mm/yy  instead of the USA please
Replies (12)
Message 2 of 13
L.Maas
Depending on where you want it. Some fields are just text fields and just can be modified. Other fields can be really date fields and are dependent on the windows settings (Control Panel > Region and Language)
Not sure, but expect that you will have to restart Revit to take effect.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 13
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member! Welcome to the Autodesk community!Smiley Happy
  • The date stamp parameter in Revit responds to the date format that you establish in Windows' control settings.
  • To format the date and time format of this stamp, modify the regional and language settings on your computer.
  • Another option is to use the Date/Time Stamp parameter and create a new shared parameter of your own.
  • You could also edit the family in your titleblock and you can change the font, size, visibility, and location of your date stamp
Message 4 of 13
I have the same issue and changed the windows setting as detailed which worked. However, you need to bear in mind that this change can affect other systems!
I noticed that this change had stopped the date formatting from working correctly in Excel so had to revert back.
Just thought i'd share...
Message 5 of 13
Viveka_CD
Hi @Anonymous
Thanks for getting back and sharing information!Smiley Happy
Message 6 of 13
guysmithB4853
Doesn't work for me.
Windows show the correct date, and everytime a new sheet is made, it uses America format.
date stamps no good for me.
I have to manually change
Autocad and Revit Technician / BIM Modeller - Call me for Building Services Cad/Revit Services
https://www.guysmithcad.co.uk
Message 7 of 13
Viveka_CD
Message 8 of 13
B.Fetzer
Hi @ all !
please have a look at this Revit Idea and vote:
https://forums.autodesk.com/t5/revit-ideas/take-date-format-into-project-units/idc-p/8303631#M23105
>>>Take Date Format into Project Units
It's a shame. On every sheet we have to change Date Format manually.
I think this is equal to all non-US-users.
So, please put the Date Format into the Project Unit Form.
See Proposal attached.
This is a verry old Idea without any reaction by Autodesk.
As Darren Carver wrote a the beta-forum in 2016 : since Release 4 in 2003 !!<<<
Kind regards, Bernhard
Message 9 of 13
carloZEYVQ
Agreed, in 2022 this issue is still not resolved and should not be shown as resolved. This is 100% a coding issue and not a user issue. this sort of thing should have been resolved a while ago and should not be something the user has to continually re-check and amend manually. If the date stamp reads correctly, so should the sheet issue parameter, based on window settings or otherwise.
Message 10 of 13
KrissCringle
Not a solution
Message 11 of 13
KrissCringle
Not a solution.  This topic is incorrectly marked as being solved.  IT IS NOT SOLVED
Message 12 of 13
RobDraw
Try going here to connect with Autodesk if you feel you can help.
https://forums.autodesk.com/t5/autodesk-technology-managers/customer-value-hub-tech-admin-update/m-p...
Rob
Message 13 of 13
mackenzie_smith7CP82
Replies for this thread have been turned off by the moderation team and a new thread has been created to discuss this topic: https://forums.autodesk.com/t5/revit-architecture-forum/re-how-to-use-a-uk-date-format-in-revit/m-p/...
