how to undo a vertical opening
georgehobel
georgehobel
I'm back...
Another simple question.  Now that I've learned how to use the "create opening" feature when designing a roof, I have found that it's not so apparent how to undo an opening.  I can click on a roof that was created and modified with an opening.  I can choose to modify the footprint of that roof.  But where do I go to modify a vertical opening that I had created?  The whole thing is invisible.  I have found it before, but don't remember where it was.  Its like hopelessly looking for a lost sock.  ????
I promise to disable spell check... 🙂
George Hobel
Reflections of Charlotte
Residential Building and Design
cbcarch
You should be able to select the Roof Opening Cut--and simply delete it.
Try using a Roof Plan or Site Plan view--it could be a cut plane / View Range problem with the view you are using.
I did a quick test by creating a new project, modeling a simple roof, using Vertical Opening Tool, the selecting and deleting the opening.
Works as expected.
If you used an in-place Void to cut the roof, --you may need to use a crossing window to select it--it may be under Generic Model category.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
georgehobel
i used the "create opening" tool.
I think I'll do what you did, create a new opening, and study what's going on as I do it a little closer.  that should reveal where it's going.  I think it's  a cut plane / View Range issue like you mentioned.  This is not the first time I've lost my void.  They're probably all in the same place.  Thank you...
George Hobel
cbcarch
Can you select it in a Section and/or a 3D View?
Cliff B. Collins
georgehobel
i can select the roof in 3d view... but i dont see the void.. havent tried a section view.
George Hobel
cbcarch
To distinguish in "Revit lingo" the Roof Opening uses an "Opening Cut" --similar to a Door Family.--technically it is not a "Void".
You can use an in-place Void family with Cut Geometry to cut a roof as another method.
So--use Tab until you select the Opening Cut when trying to select it.
Cliff B. Collins
georgehobel
Thank you Cliff... I was able to see the "opening cut" in the section view.... I appreciate your time....
George Hobel
