T&G problems
T&G problems
T&G problems
I am unable to make my T&G wider. Is there anyone out there that could help?
Can you post an image or file to help explain?
Corsten.Au
Hi
You cannot change the existing cladding fill pattern..
for Tounge and Groove Cladding, you will need a new correct " pat " file to
import and use it..
Corsten
Building Designer
Viveka_CD
Hi @Anonymous
I see that you are visiting for the first time. Welcome to the Autodesk community!
Are you talking about tongue and groove cladding or flanges?
If it is cladding then try the below method:
Create a T&G profile as required. You can create a custom family with a pattern. Use array and wall sweep and enter the number of sweeps/reveals that you need for the wall.
Screencast HERE
Let me know if you have any questions.
...or, perhaps the OP is speaking of a surface pattern, as @Corsten.Au mentioned?
...or Tom & Gerry? Smiley Wink
Viveka_CD
@barthbradley looks like @Anonymous is offline.
Let's hope he comes back to clarify.. till then T&G is a mystery Robot winkSmiley Very Happy
