How to sheet parameters value to view parameters value as both as same.
Hi I was using a project parameter for suppose level sequence and sheet last sequence number.(eg: 01/10001).
But I tried to assign this parameter to view parameter so that this (eg: 01/10001) value has to be shown on the sheet. I don't wanna give it again in the view parameter.
I want one parameter to serve both view and sheet family at a single instance.
If there is any way please let me know.
Note: I've tried to export the project parameter and used in it view title. It's working but the problem is I need add the value manually in both sheet instance and view instance.
Thanks in advance.
You want a View parameter value and a Sheet parameter value to be the same? How would the sheet know which view port contained the view parameter it was suppose to use?
It is fundamentally not working.  What about Legend views that can reside on multiple Sheets?
Your best bet is create a View schedule, group by Sheets, un-itemize so All Views on a Sheet collapse to a single row, and enter the value for that row to match that of the Sheet.
As I was going to assign a single plan view for a sheet
As I was going to assign a single plan view for a sheet.
But I think there will be a better option.
Sahay_R
Possibly an instance based text parameter that is associated with both Sheets and Views. You will, however, need to manually enter the required values.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
yes.. that's how i worked it out but still i want to edit it manually.
