How to sheet parameters value to view parameters value as both as same.
10:43 AM
- Mute
- Permalink
- Report
Hi I was using a project parameter for suppose level sequence and sheet last sequence number.(eg: 01/10001).
But I tried to assign this parameter to view parameter so that this (eg: 01/10001) value has to be shown on the sheet. I don't wanna give it again in the view parameter.
I want one parameter to serve both view and sheet family at a single instance.
If there is any way please let me know.
Note: I've tried to export the project parameter and used in it view title. It's working but the problem is I need add the value manually in both sheet instance and view instance.
Thanks in advance.
Thanks in advance.
