How to save a view in revit to the drafting view directly
chhuanmawia18
608 次查看
4 条回复
1 条消息(共 5 条)
chhuanmawia18
Is there a way to save a view in revit directly to the drafting view directly . I export the view in 2d cadd format and then import it back to the drafting view again and i found this cumbersome . Is here a way to directly import the view in drafting view without having to export and then import it
0 个赞
609 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
Mohamed-Nassar
as you do this is the most sample way to save as draft view.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
0 个赞
3 条消息(共 5 条)
hmunsell
Why are wanting to save a Revit view as a drafting view? Can you explain why you want to make a drafting vs using a section, callout, etc...?
Howard Munsell
4 条消息(共 5 条)
chhuanmawia18
It's kind of a workaround for me because i wanted a specific view that was perfect but when i change the other elements that view also changes and i have to adjust all over again . I just wanted to save that particular view wihout the later changes affecting it
0 个赞
5 条消息(共 5 条)
Search for freeze drawing tool for refit. It is for older versions but might just work for current one.
0 个赞
