How to save a view in revit to the drafting view directly
chhuanmawia18
chhuanmawia18
Is there a way to save a view in revit directly to the drafting view directly . I export the view in 2d cadd format and then import it back to the drafting view again and i found this cumbersome . Is here a way to directly import the view in drafting view without having to export and then import it
Mohamed-Nassar
as you do this is the most sample way to save as draft view.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
hmunsell
Why are wanting to save a Revit view as a drafting view? Can you explain why you want to make a drafting vs using a section, callout, etc...?
Howard Munsell
chhuanmawia18
It's kind of a workaround for me because i wanted a specific view that was perfect but when i change the other elements that view also changes and i have to adjust all over again . I just wanted to save that particular view wihout the later changes affecting it
Search for freeze drawing tool for refit. It is for older versions but might just work for current one.
