- Mute
- Permalink
- Report
Is there a simple way to control the rotation of annotation text?
I found the following options for the "Read Convention" parameter in the corresponding dimension style family:
Text > Read Convention: Horizontal / Up, then Left / Up, then Right / Left, then Up / Right, then Up
But as the Viewports have been rotated themselves[1], these options do not work as needed...
One way I could imaging to solve this problem would be a type parameter "Text Rotation" which would allow to rotate the annotation texts individually...
Any idea how to solve this problem?
Thanks for you help,
Dietrich
[1] One of the viewports was rotated by 90 degree counterclockwise via the Viewport "Rotation on Sheet" type parameter; the other one by using a callout and rotationg it by 180 degree:
