Hi, I am trying to move the text on my dimensions closer to the dimension line using the "Text Offset" parameter in the type properties. However, when I do this the masking of the text also masks the dimension line when the dimension is at an angle. I need the masking on (I can't just change the text type to transparent). Does anyone know of a way to reduce the amount of white space behind the text in a dimension? Thanks!
