I am using timber 50*100 timber beam for my building but it is showing strange in my elevations. In one elevation it shows it has no depth like in the picture. I am trying to make it seem right, without pulling it down or up manually, what can I do?
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Check with Detail level...
Shade it to get the actual view..
your elevations are not exact perpendicular to beam elements so its gonna
show two sides in the elevation.. ( am sure you are aware of this )
Cheers
Wonderful, it worked.
Thank you Ganesh!
As to the beams, how do I make sure they are perpendicular to the elevations so it only shows one side?
Thank you very much for your suggestion and your time.
Actually, I just rotated the plane and it fixed the problem.
Thanks again Ganesh!
OMG... I have fought this dammed program for 2 days and now to realize it was a simple click.. THANK YOU!
