How to recover unsaved file in Revit?
7 REPLIES 7
Message 1 of 8
theongubs
37688 Views, 7 Replies
hi.
is there any way a file that was not saved when the "do you want to save '' icon pop up, can b retreated?
I mistakenly press "no"
7 REPLIES 7
Message 2 of 8
cbcarch
in reply to: theongubs
See if you have a "shadow copy" saved on your PC and/or server.
Find the current .rvt file in the windows folder, right-click, go to Properties, Previous Versions, and see if there are any there.
If so, you can restore the latest version from there.
Title renamed to: How to recover unsaved file in Revit?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
theongubs
in reply to: cbcarch
what is a shadow copy?
Message 4 of 8
Viveka_CD
Hi @theongubs
I would try the suggestion by @cbcarch.
Let me know if that helps and if you have additional questions, please make a new post.
Message 5 of 8
It is a function of Windows Server that allows X amount of backup saves of a file.  Go to the network location of your file, right click and select Properties. Look under the "Previous Versions" tab.  If there are files there you have shadow copy turned on, nothing, it's not.
Else you have to recover a previous version through the Restore Backup (if a central model) by selecting the central model in the network location or find a file with .000XX after your file name.
Message 6 of 8
Viveka_CD
Hi @theongubs
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 7 of 8
Oh....it was never saved?  You are out of luck.
That's like getting the phone number to the girl/guy of your dreams written on your car and you wash it before writing it down in ink.
Message 8 of 8
I LOVE how Autodesk marks these things as SOLVED!
"Hey this is broke. Can you fix it?"
"No. Its broke!"
Problem solved!!!!!!!
