Attached is the family in question. I am wanting to know what the best way would be for me to set up a view filter/template to show only the anchor bolt. The reason would be for an anchor layout plan where I don't want to show the rest of the connection, just the anchor bolt.
A semi-unrelated question - the anchor bolt is a default Revit family, but I can't figure out why I can't link the length to my Anchor Bolt Length parameter in my BC3 family. I think it is because in the anchor bolt the length is a sum of a few different measurements. Any way to get around this?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Several ways to do that...one of the neat methods is to use subcategories:
In your case, structural connections already has preset subcategories for bolts/anchors/plates...etc so just edit the family and make sure each element is set to the proper subcategory
PS: If there is a subcategory which you need and not listed...simply go to Object Styles in the Family and create NEW
@hmunsellyou feel like screencasting this one? ![]()
The length of the Anchor bolt L1 is driven by a formula L2 + L3 - a
You need to associate the parameter L2 and L3 and a with parameters in the host family
To do that...
well i was making one but OP said they could do soooooo. ![]()
here you go....
Howard Munsell
