Hi use Revit LT.
I want to offset the property line with a red outline around the property .
I edit the property line and copy the (complex shaped) lines
then start a detail line or filled region and copy the lines in the same place
but when I want to offset this new line in edit mode, if you tab the lines, only a part of the
full outline is selected. with the offset tool I can not select all lines
how do you do that?
thanks
Stefan
Solved by dzanta. Go to Solution.
perhaps the lines are not completely connected so the Tab function only grabs the lines that are connected end to end...?
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Are you saying that when you Finish Sketch Mode, the hatch fill does not adjust to meet the revised sketched boundary?
