- Mute
- Permalink
- Report
Hi use Revit LT.
I want to offset the property line with a red outline around the property .
I edit the property line and copy the (complex shaped) lines
then start a detail line or filled region and copy the lines in the same place
but when I want to offset this new line in edit mode, if you tab the lines, only a part of the
full outline is selected. with the offset tool I can not select all lines
how do you do that?
thanks
Stefan
Link copied
