I have a garage where its 20.5 deg (truss) gable roof meets a simple sloped roof (12.5 deg) about halfway up the gable roof (see image below).
I modeled the two roofs separately and used the join command. But since both roofs overhang the side of the garage wall, I ended up with the gable roof sticking out below the simple sloped roof (shown in grey in the image below).
What is the proper way to model these roofs to get a clean result? I am using Revit LT 2022. Thanks.
Thanks @ToanDN , but my case is a bit more complicated. In the first image below, my 12.5 deg roof is in blue. Not only does it need to join the 20.5 gable roof over the garage (on the far right side), but it also needs to join the side of another 20.5 deg gable roof (on the far left side). That is, my main roof is a T-shaped hip and valley roof with gable ends (which was straightforward to model).
The Join Roof command does connect to the big main roof (running left-right) but it leaves me with the overhang problem mentioned initially (i.e. the gable roof sticking out below the sloped roof at the garage gable end). But when I join those roofs, the 12.5 deg sloped roof can't then be joined to the roof on the far left. I could just drag the left end of the 12.5 deg roof over to that roof. The second image below shows the shape of the main roof with the 12.5 deg sloped roof hidden to help clarify things (hopefully).
Out of curiosity, why raise the roof at the plate for, what looks like, a carport or patio roof? I can kind of see the reason to over-frame, but that wouldn't have any effect on the Main Roof, nor necessitate raising the wall height.
Following @barthbradley comment from another thread I created this one by manually inserting Split lines.
1) Create two separate roofs and join them using just the regular join command. This is just to get roof lines.
2) Draw a bunch of reference planes over which you'll place split lines, and add a bunch of spot elevation dimensions which you'll use to input the heights. Take a screenshot of these dimensions, and delete them.
3) Delete the smaller roof, edit the big one and remove all slopes.
4) Modify Sub Elements, and trace over reference lines with split lines. Select points and input heights from the screenshot. When done move the whole roof to the correct height, regular move in elevation view.
5) That's pretty much it. I don't know why, but you do end up with "brake lines" on faces, even though they're not actually there, as seen in 3D and sections, faces are flat. Unfortunately these have to be manually set to invisible with Linework in every view.
Actually took surprisingly little time, though I do hope someone knows a more automated way of doing it.
not sure it works for LT , but what about using Roof by Footprint -two roofs one over one other ?
Constantin Stroescu
