How to make Walls different materials
aadamsA2F2Z
aadamsA2F2Z
Whenever I change a wall material, it changes all the walls placed. Is there a way how I can change one wall to be a different material?
RDAOU
@aadamsA2F2Z
Duplicate the Material >>> Rename it >>> Go to Appearance tab >>> Duplicate the asset >>> rename as needed and change appearance image/color/bump...etc as necessary
aadamsA2F2Z
So i tried this today, and it still changes every wall in my design instead of just one wall.
RDAOU
@aadamsA2F2Z
Material is a type parameter...if all the walls are the same type => they will all change material
When you need walls of different material you have 3 options:
  1. Duplicate an existing type to create a new one >> Set new material as shown in previous reply
  2. Use the Paint tool and paint a new material to the related face of the wall
  3. Convert wall to parts and uncheck the option Material by Original
Option 1 is most probably what you are looking for
aadamsA2F2Z
how do i make them different types of parameters
RDAOU
You cannot ...they are hard coded as type parameters in the Wall system family
You need to create a new wall type (like: Brick Gray / Brick Red  / Brick White...etc) and give it a new material or use paint tool
aadamsA2F2Z
dang that sounds like a lot of work I am going to have to redo
