Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
How to make parameters like these
5 REPLIES 5
270 Views, 5 Replies
how.JPGLike here instead of putting values to change the dimension of the material,you can just stretch it by pulling arrows.
5 REPLIES 5
in the family create Ref. Planes to align and lock the geometry to, pull dimensions between the Ref. Planes, and then label the dimensions with instance parameters.
In Family:
In Project:
in reply to: barthbradley
Thanks,although there is one problem  for example
If I drag the arrow highlighted,it also move the object along with it.
why4.JPGAlso how can I make them appear in 3d view
Make sure not locking any dimension instance parameters.
And below is the answer I provided in your exactly same topic regarding 3d:
" On top of what @cbcarch has said, the parameters must be Instance, not Type parameters.  If you want the grips to show in 3D, use Reference Lines instead of Reference planes."
don't use an equality constraint
But the problem is still there even if I am not using equity constraint.
Forma Design Contest
Technology Administrators
