How to make line type editable in family property?
theresatlninhMWWN4
Message 1 of 21
theresatlninhMWWN4
I didn't want to edit line type of a family through edit the element visibility. How do I make line type editable in family property edit?
Accepted solutions (4)
Replies (20)
Message 2 of 21
Huh? I'm not following.  What exactly do you want to do?
...maybe post the family along with the explanation so that the boys and girls can follow along at home. 😉
Message 3 of 21
theresatlninhMWWN4
I try to change line type (ex : solid to dash) using family property panel
instead of right click and override graphic in view.
Thank you!
Message 4 of 21
mhiserZFHXS
You would have to make two lines or extrusions on top of each other with the different line styles you want, and then use visibility parameters to select the one you want to show.
In most cases, it is just better to utilize the object styles feature to manage these types of things.
Message 5 of 21
Thank you!
- Draw lines under a subcategory with solid pattern, assign the lines to a Yes/No parameter named Solid line
- Duplicate lines and move them to a subcategory with dashed pattern, assign the lines to a Yes/No parameter named Dashed line
- Use the formula for Dashed line parameter: not (Solid line)
- Load the family to the project and you can tick Solid line box to show slid lines or Dashed line box to show dashed lines
Message 6 of 21
theresatlninhMWWN4
I have another question relate to lines.  How can I create custom line  that able to turn different angle and still is continuous.  Right now, ever time I turn different angle, I draw a new line that is not continuous (not 1 polyline) .
Message 7 of 21
Chain Segments is the best you can do.
...there would be a way - with a little work -  to do this via a Multi-Point Adaptive Family pulling a Divided Line. The nodes of the Divided Line could host an element that is repeated along the Divided Line.
Why a Repeated component on a Divided Line Path is better than an Array » What Revit Wants (wrw.is)
Message 8 of 21
See attached example of using curtain to draw line with embedded annotation.
Message 9 of 21
theresatlninhMWWN4
How do you do chain segments. I tried to look on google, but nothing came
up.
Thank you,
Theresa Ninh
Message 10 of 21
up.
Thank you,
Theresa Ninh
Select Chains of Walls and Lines | Revit 2021 | Autodesk Knowledge Network
Message 11 of 21
theresatlninhMWWN4
I tried to add new types  dash line with arrow for the custom CW lines.  It shows up on the Browser panel, but I just can't add it to draw a new type of curtain wall beside hot and not hot.
Message 12 of 21
luke.johnson
You could consider using a nested Line based family.
Inside that family you could use visibility parameters as mentioned by some replies above.
Luke Johnson
Message 13 of 21
theresatlninhMWWN4
I try to add a new type for CW line with text. The new type shows up on the browser, but I can't find it under curtain wall to use it. I even try to drag from the browser, but it doesn't work.
Message 14 of 21
Duplicate the curtain panel type, edit the label parameter, create a new curtain wall, edit type, duplicate l, and assign the new curtain panel type to it.
Message 15 of 21
Duplicate the curtain panel type, edit the label parameter. Draw a curtain wall, edit type, duplicate, and assign the new curtain panel type to it. Repeat for as many line types as you want.
Message 16 of 21
theresatlninhMWWN4
I try to turn off the CW line on the view I don't want it to show up. Only the line is turn off not the letter tag.  Is there a best way to make the line show up on the view it is draw on?  Thank you!
Message 17 of 21
Create a filter to turn off walls using type name criteria.
Message 18 of 21
theresatlninhMWWN4
Thank you! It works.
Message 19 of 21
theresatlninhMWWN4
One problem I ran into is I tried to change the thickness of the line through object style in the family.  It doesn't change on the project.  The line only get thicker when I hover the line.  Can you let me know what is wrong?
Message 20 of 21
Create a subcategory in the curtain panel family and assign it to the symbolic line.  Load in the project, open Object Styles > CUrtain panels > change the Width of the subcategory.
