how to make curtain system diagonal
Message 1 of 22
how to make curtain system diagonal continue with shipping container degree?
Replies (21)
Message 2 of 22
is someone know why i cannot attach file please?
Message 3 of 22
Avaris.
Select your curtain wall and adjust the angle of your grid:
Message 4 of 22
thanks, degree is not so good, i want to continue the shipping container line(as in photo) without degree
Message 5 of 22
Avaris.
Maybe I don't understand your question, but if you want to make a slanted curtain wall. Create a mass of the volume you indicate as yellow and apply a curtain wall to it.
Message 6 of 22
Viveka_CD
Hi @Anonymous
Can you try to zip your files and resend?
Message 7 of 22
Viveka_CD
Hi @Anonymous
Please see AKN article: Creating diagonal curtain grids
Let me check with the team for any other documentation on this, meanwhile, send us your file.
Message 8 of 22
Viveka_CD
Hi @Anonymous
Let us know if the suggestion by @Avaris. helped with your issue.
Message 9 of 22
RAR FILE
Message 10 of 22
are you meaning that you want to slope your Curtain Wall?  Apply Curtain Wall System to Mass Faces which are sloped.
Message 11 of 22
Viveka_CD
Hi @Avaris.
Thanks for sharing your model.
Curtain system from a mass is the way to go, but I'm looking for more feedback from the team.
Also, are you looking to match the shipping container material onto the mass?
Message 12 of 22
I know how to make curtain system from a mass, The problem is how to make the mass as specific shape as in picture in the begining. Screenshot_2018-10-28-14-07-42.png
Maybe this picture will help to explain, how to make mass in this spesific shape ?
Can you open rar file i have attached please?
Message 13 of 22
So you know how to apply a CWS to a mass face -- you just don't know how to create a mass. Is that correct?
...here's a starter video. Other more advanced ones are also available on-line.
https://www.youtube.com/watch?v=RNIPdNKZ4FQ
Message 14 of 22
I know how to make simple mass and how to apply curtain system to it.
But how to make this spesific mass i havent succeded
The shape of the mass is complicated
Message 15 of 22
It looks challenging, but not intimidating.  The key is WORKPLANES.  If you saw the video I posted,  this was addressed at the very beginning.  Did you notice his very first issue? He didn't have the correct Workplane set current.
Message 16 of 22
Corsten.Au
check out adaptive curtain panel, curtain grid.. you can have any design there..
bit learning curve though..
Corsten
Building Designer
Message 17 of 22
Also already familiar with work plane...
The problem i dont know how to make frame accurate in work plane
Already pick the correct work plane the i want to draw the mass under shipping container till the floor (and ofcourse both sides)
Thats the stage i am stuck, please help... My project is in hold
Message 18 of 22
If I am understanding correctly, you cannot create the mass for the curtain system.
I opened your project and the mass seems to be an extruded triangle, it's just from the side, not from the plan.
Here is a screencast with instructions to create it:
Message 19 of 22
so so helpfull
thanks a lot!
Message 20 of 22
i have tried to make each side.. so simple and didnt figure it out... thanks
