hey again 🙂
I'm editing a family type of sign.
i placed model text on both sides. the text come from parameter.
Sometimes the back side will have no text at all, the thing is the model text value has to include something otherwise revit wont accept the value.
https://www.youtube.com/watch?v=4H6gS-LJBVg
is there a possible sulution for that?
Solved by RDAOU. Go to Solution.
Well i have a y/n parameter for "Both sides sign". when it's off -> the visible value of the back model text connected to this parameter is set to not visible. (as well as a text label on plan view that disappears when its off).
But nevertheless, the model text value always exist and has, or has not text in it.
if it has not text in it, revit will display this message anyway (and halt)
yes - i want that.
But revit don't accept empty text field. he say there must be some text. even if the visible parameter set to no, it want text. did you see the erroe message on video?
My project has lots of signs which has empty back side - thus - the "back text" parameter is empty in all of them.
are you saying that i should change the "back text" parameter on all of them from " " to "empty"? thats what you meant?
This family im building now will be used by some more workers, if they leave this field empty (which is a reasonable thing to do) they'll get error messages, I'm trying to make the family files as user friendly as i can.
there's no anyway i can handle this problem?
If you are afraid that the users blank out the Text Parameter, control it with an IF statement …
Edit...When back text is visible, is it always similar to that of the front?
@danezeq wrote:My project has lots of signs which has empty back side - thus - the "back text" parameter is empty in all of them.
Are these pre-defined texts on the back/front?
When the text is defined in advance as fixed options instead of user input... the user chooses "a", "b", "c" for example, instead of being able to type in "d"... but you can build the family in different ways i suppose, it is not entirely relevant/interesting for you here maybe. Well, it could be... not sure.
Why don't you use 2 different families
Then you wont need to have anything empty !!
at this point, after you all helpt me build the almost perfect family, it'll be so much hassle. But i think it's a great idea, im saving it, maybe ill change it the future.
