Message 1 of 11
- Mute
- Permalink
- Report
If I want to use cold formed metallic structure, how do I structure the metallic stud layer if there is an insulation batten in between the studs?
The actual studs will be a structural frame system but the insulation is a layer of the composite wall
Do I need to adjust the thermal conductivity to match the insulation layer and also change the drafting hatch pattern ?
What if the insulation layer is thinner than the studs so there is another air cavity left?
What is the usual way?
