how to join curtain wall panels at the corner?
5 REPLIES 5
alexlj
1167 Views, 5 Replies
Hi All
Just wondering if it's possible to have these curtain wall panels joining just like how the walls are trimmed?
or I have to turn them into normal walls to achieve that?
5 REPLIES 5
ennujozlagam
in reply to: alexlj
refer to this LINK and see if helps. thanks
alexlj
in reply to: ennujozlagam
thanks but that's a corner mullion. This corner should be just simply trimmed together with no edges.
ennujozlagam
in reply to: alexlj
try this configurations , adjust your curtain panel manually and see if helps
RDAOU
in reply to: alexlj
@alexlj
Edit the curtain wall type and replace the Glazed Curtain Panels with a Basic Wall...subsequently you will have a seamless corner that can be mitter joined
alexlj
in reply to: RDAOU
Thanks. One side of the wall just don't mitre joint. After numerous attempts I found the trick. on the wall joint options bar click the disallow join then click on the corner again and allow join.
Forma Design Contest
Technology Administrators
