it looks like we can't combine text parameters in a family, but wonder if there is a workaround or other solution ideally not requiring dynamo?
What I want to do is to have a type in a family and want to automatically change the model number and type mark with the options selected. For example, a fixture has a model number "fixture" and if I add the option (yes/no instance parameter) of a relief-valve, the model number would be "fixture-rel". I could do that with more types, but with many options possible, would end up with very many types. I also don't want to do that in a schedule, since this will differ for each family depending on what a manufacturer offers. It also may not work for schedules since that may mess with how i order items and I also need to manipulate the typemark. I also don't want to use a Dynamo script because I want to instantly see the correct name (and the user may forget to run the script).
I saw in the ideas forum someone already asked for that and I voted for that. But voting alone won't help me 🙂
Any other workarounds?
thanks. I thought of something similar to that. the problem is, I still would have different family-types and they might consist of different first part of the modelnumber. So that if-statement would have to be different for each type. What you showed would work if I only have one type.
I tried to write that if-statement into the "Value" column. It first looked like it works, but in the model the text parameter actually just shows the equation and not the result.
I also wanted to use interim text parameters to easier fill them out for the family. Then use those to "build" the new "text".
An example of a piece of equipment would be a light fixture. I would have a type for each major category (e.g. 2x2, 1x4, 2x4 and each with the LED lumen packages. this could be 10= types and each have a specific ies file. Where I want to add the above smartness is where the fixtures have options. they each have a drywall-kit, surfacemount kit, and other features. Currently I have to create a separate type. Multiplying that i end up with 30+ types and ideally I woudl spec more features. So each of the 10 types needs a different type of "first part of the model number"+ "feature model number". The same has to be done to create a new typemark (which would be an instance parameter". My hope is once I figure out concatenating, I can simplify many of my families (fewer types) and have fewer errors creating new types. I also would be able to add more options that require a new model#.
