How to hide value 0 in schedule
Message 1 of 19
Hi everyone,
I want to show the below schedule as below but without number 0 in the SQ field.
I try to search all over, but have no idea how to made it.
I also try to convert number to text for an IF statement, but also can't find any formula to change number to text.
Could you please help me,
Thanks a lot,
Replies (18)
Message 2 of 19
zemeraloni
Hi @Anonymous
you can use filter to set that only area above 1sf will be visable, see attached image.
Message 3 of 19
Thanks for response, but if I do that, the POS area can not show on the Schedule.
I want to show all Area, but without number 0, because it look nonsense in a schedule 🙂
Actually, I just want to show Blank on SQ column for POS area,
Message 4 of 19
zemeraloni
Well then i don't know how to do that sorry..
You can do thing like the image below but i'm not sure if it's looks better area 2.jpg
Message 5 of 19
@zemeraloni: Thanks for your help. I hope that could be ok, but it is not. Anyway, I'm very thank you for your very quick response.
Message 6 of 19
Ilic.Andrej
Take a look at this concept.  Click on the images to enlarge.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 7 of 19
@Ilic.Andrej: That's very impressive. Thank you so much. But I still can't have total in New Area. 😞
I think it is really close to the perfect solution.
Could you have another light for me?
Thank you again and again for your time.
Message 8 of 19
Ilic.Andrej
Sadly, I think it can't be done. This is the best I can do:
Andrej Ilić
MSc Arch
Message 9 of 19
Where did the SQ values come from?
Message 10 of 19
Thank you so much. You do the best, mate.
Message 11 of 19
@ToanDN: SQ is a calculate parameter take value from Area and a Y/N parameter to get the construction area SQ=IF(Built,Area/9.29m2,Null)
I tried to use Null value, but when use the calculate total on Formatting, the number 0 is appeared again.
Message 12 of 19
If you want to keep them in one schedule then you need to accept the 0 subtotals (right pic).  or you could split it into several schedules and set some to not calculate total (left pic).
Message 13 of 19
@ToanDN Thank you. That is the solution I tried before, but actually, I prefer how to combine all schedule in one than split them. Because I will face to multi unit projects, and must create a lot of schedule like that.
But, have somethings better than nothing 🙂
Message 14 of 19
I would keep it as one schedule too.  I don't think nobody is going to complain about the 0 subtotals.  If they do, create a white text type and use it to mask the subtotals.
Message 15 of 19
opferjohn
What is Area Null Value?
Message 16 of 19
@opferjohn It still has 0.00 in total. I reckon that is always give a value for a calculate parameter.
Message 17 of 19
nkovach
This rocks!  Thank you for contributing to this discussion.. I would never have thought to pull from these null values.. genius!
Message 18 of 19
seanUFNGF
I found this awesome, simple solution and if worked like a charm!
https://www.revit.news/2019/08/hide-zero-values-in-revit-schedules/
Message 19 of 19
Davidminkov_work
You are the boss
