How to hide the Floor Boundary in Plan...?
jlogesh1992
Message 1 of 14
jlogesh1992
Dear Friends,
I have Differnt case to hide the Floor Boundary Line in Shop drawing,
In this case I am not able use Line Work (LW) Tool because i have to make lots of line to invisible mode,
If i hide the floor it self in Visibility Graphics Spot elevation for the related floor categity also hide,
So i need a another solution to hide the Floor boundary line,
If i use the white line for surface line, it make another problem. all the joining area (Floor to wall,) boundry line are not visible in print.
Please guys give me a solution i was struck this issue very long back
Floor BoundaryFloor BoundaryIf i use the white line for surface lineIf i use the white line for surface lineMy Out put is like this... in Lot os area..!My Out put is like this... in Lot os area..!
Replies (13)
Message 2 of 14
Corsten.Au
Try Transparency..
Transparency in Category..Transparency in Category..
Corsten
Building Designer
Message 3 of 14
jlogesh1992
Dear Ganesh,
I have tried Transprance option also,
1st thing its not work and also If i make a surface transplant i can see the element under the floor.
Message 4 of 14
Corsten.Au
Hello
To hide the elements below the floor, just fix the view range..
transparency + white boundaries should work..
If this doesn't help then I hope someone will come up with a solution.
best luck
Corsten
Building Designer
Message 5 of 14
jlogesh1992
Dear Ganesh,
We have Lot of area is like this, It like a huge project,
So i am looking for Another way to solve this issue, Because the same presentaion i need to follow morethan 500 Sheets.
Any Way Thank You For your support, If you Found any Way Please let me Know,
Thanks & regards
Loganathan J
Whats'up : 7418580708
Message 6 of 14
Just to understand you logic here, you want the spot elevation reports something invisible in the view? If the floor is physically and correctly in that location then why hide its edges?
Message 7 of 14
jlogesh1992
Deaar ToanDN,
Actually i was working the block work layout, here i want to show the Finished floor level and i don't want to show the floor boundaries, please read the full story.
And here some room two types flooring is coming for the architecture purpose, so that i have create the two different boundaries for two different floor,
and then flooring pattern no need show in block work layout drawing, so that i have hide the flooring surface, then floor boundaries are visible like a attached image-01
IMAGE - 01IMAGE - 01
SO THAT i WANT TO HIDE THE FLOOR BOUNDARIES HERE,
If i make the floor boundaries in white color, Floor to wall connection area lines are hide, so that i want to make the floor boundaries to be hide.
THANKS & REGARDS
LOGANATHAN J
Message 8 of 14
archragab
Observer
Observer
Are you found a solution??
Message 9 of 14
mark.mountain
Seen other forums where people discuss a dynamo solution. A script that can select all the floor edges then use the line work tool to override them with invisible lines. Down side is you'd have to do that on every view or complicate the script further and let it allow the user to pick multiple views.
Message 10 of 14
o.shahroorAPR34
Hi
after a lot of ideas and thoughts i managed to reach a good enough workaround, you basically go to line patterns, create a new line, you can call it ''invisible'' and then add a dot and space.. in space you can add 10000mm.. this way you will have a line type that has only a point each 10 meters which is not noticeable.. you can raise the value also if needed.. after that you go to object styles and set this line pattern for floors and that is it.. the only down side here is that floor lines will be hidden everywhere in the project meaning that you need to switch often from this line pattern to the normal solid line whenever you are printing. Hope this will help
Message 11 of 14
azad.Nanva
This is not work
Message 12 of 14
azad.Nanva
Make another roof over the old one a few millimeter, name that invisible floor(you can use another parameter like yes/no or only in plan or what you want) then hide that in all other views (2d and 3d) by the filter.
Message 13 of 14
loulwakharbotly
I have a solution .... remove the link for the wall and reupload it .... next time make sure to add the link for the wall last of the links.
but all the dimensions and tag will be deleted and need to redo
Message 14 of 14
loulwakharbotly
Could you please provide us with this script
