How to Hide Crop Region in multiple views?
Is there a way to hide crop region in multiple views at once? Or can you hide crop region using a view template?
Thank you!
chrisplyler
Have nothing selected.
Look in your project browser and use control-click or shift-click to select multiple views at the same time. Turn off the Crop Region Visible parameter for all of them at once.
I tried doing what you mentioned;
Selected multiple views and turned off crop region but it doesn't do anything.
Highlight a bunch of view from the Project Browser and uncheck the Crop Region Visible box.  If it does not work, try to switch from Windows 7 Aero them to Windows 7 Classic theme (sorry I don't know about Windows 8).
Great, it worked! Thanks!
chrisplyler
What worked? Switching from Aero to Classic in Windows settings? Wierd. I use Aero and it works fine for me. Why would that have any effect at all?
When my computer was newly setup with Aero, I was not able to change parameters by selecting multiple Views and Sheets from Revit browser.  Switching to Classic fixed it.  Then I can switch back to Aero and it remained working.  Yes it is weird indeed.
