Mirror Project Tool - Not working with Revit Architecture 2013
Hi! I am working with Revit Architecture 2013. I have a two story home that I want to "flip" the garage side. I am trying to get revit to mirror the home with the Mirror Project tool (Manage Tab, Position, Mirror Project). My software just hangs at about 25%. I tried using two different PC's with Revit installed and both machines hang. I was wondering if anyone found a "workaround" for this? For example is it the roof lines, text, tags, site, etc. that cause the software to hang? Thanks! Rob
matthew.d
Hi @Anonymous,
Sorry to hear about your issue, I see you have a few other posts about this. My best advice is to limit the amount you are mirror. Also take a look at this article about moving objects, it might be best to work around this issue and use the rotate tool. Make sure you are up to date on you 2013 version.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Matt,
Thanks for the info. I will take a look. I appreciate your feedback.
Take care,
Rob
