Greetings to all participating members of this community.
I have decided to make this consultation directly to the forum, finding no answer by other means.
How can I get certification from Autodesk Professional or BIM manager. I would like to know if there is any way to obtain such certification, in Nicaragua, in a training center or online.
I thank all those who contribute their ideas and possible solutions before hand. Thank you.
BIM Manager won't help...If there isn't a testing center there, then perhaps a visit to Autodesk University later this year is a good idea? Then you can test for whatever you want.
Hi there @jonotega1990
Can you try the link below:
For ACP
http://www.certiport.com/Portal/pages/ACPSearch.aspx
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Autodesk is aiming to propose a role based certification : Autodesk Certified Profesionnal , BIM Manager in Building Design. The exam is in beta now and will be released maybe in few next months.
The big advantage here is that you don't need to go to an examination center to take the exam but you can do it from home ! as all the other ACP or ACU certifications.
for more details please visit The pearsonVue Platefom :
https://home.pearsonvue.com/autodesk
Good Luck
