Hi everybody,
I'm trying to do a tag with a conditional statement in a formula.
Can I do something like that?
I wouldn't like to show the quality value in the tag when this value is equal to "C30/37" in a column.
Thank you in advance
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You need an on/off shared parameter "C30/37". Then a text shared parameter which checks the other.
<C30/37 on/off parameter> = true / false
<text parameter> = if (<C30/37>, " ", "quality strenght")
...or if(not(<C30/37>),"quality strenght"," ")
The principle as mentioned by @martijn_pater is correct, however, use a different naming style for parameters
- you cannot name parameters using special characters > < [ ] : ? \
- you shouldn't include computational syntax in parameters name - + / *
Ha, that's funny.:) Those are just <input parameter here> brackets, I guess someone could misread those...
...as to say you are right to point that out. Also I think I switched the text returned by the if statement, so let me rephrase and use some color;
You need an on/off parameter, let's say MySharedParameter1. And another text parameter, let's say MySharedParameter2. Shared parameters for scheduling.
MySharedParameter1 = true / false
MySharedParameter2 = if (MySharedParameter1 ,"quality strenght", " ")
...or if(not(MySharedParameter1 )," ","quality strenght")
Feel free to mark as solution and @RDAOU in addition. ^^
